Thread: MODRTU32 symbolic address
    20.12.2017
    5
    Default MODRTU32 symbolic address
    Dear COPA DATA forum members,
    To sum up the story, I am using MODRtu32 driver, and what I have seen symbolic address is like in IEC - 61850 (please see attachment).
    Can somenone explain me if MODRTU32 uses symblic address for reading variables ststuse nad values,or it all goes through variable name using Modbus standard byte order?
    Is there any article/forum post/ documnet where I can see how this communication works?
    DamirO
    25.06.2012
    152
    Default Re: MODRTU32 symbolic address
    Dear DamirO,
    Thank you very much for your post.
    The symbolic address field contains a MMS address as the respective variables were previously linked to an IEC850 driver (that supports symbolic addressing). As you can recognize this variable property field is now grayed out so that the symbolic field is no longer used by the driver in the runtime.
    On the other hand, you can confirm that symbolic addressing is not supported by the MODRTU32 driver:
    Thank you very much.
    David Cerdeira
    20.12.2017
    5
    Dear David,
    Thank You for the reply and for the explanation.
    Damir
    14.10.2019
    Thanks for this information. It useful
  1. Replies: 3
    Last Post: 28th July 2017, 01:08
  2. MODRTU32 Timeout bei TCP/IP
    By michab in forum Drivers
    Last Post: 7th April 2017, 14:06
  3. modrtu32
    By anshasi in forum straton / zenon Logic
    Last Post: 13th December 2015, 13:20
  4. How to set the symbolic address????
    By nollh in forum VSTA
    Last Post: 12th March 2015, 10:41
  5. Modrtu32
    By jahidbagwan in forum Drivers
    Last Post: 19th August 2014, 12:56
