Can anyone provide some direction on how to connect to TIA15 Simatic s7-1500 with Zenon 7.5 build 55804 64Bit? We are not having any luck with the S7-Driver for S7-1200/1500 driver. Is there another driver we should be using?
Dear photomaddd,
Thank you very much for your post.
First, make sure you have the TIA 15 *.ap15 project file and this is linked in the driver configuration (Options tab) in the TIA project field/path.
In the Connections tab, make sure that the connection newly created uses the same CPU Name as defined in the TIA project.
To add variables in the zenon project you can use the S7TIA online variable import. Make sure at least one of the variables is used in the runtime.
You can find more information in the driver documentation Drivers -> S7TIA)
Please let us know if you still cannot establish communication afterwards. If needed follow the steps described in the documentation topic: S7TIA -> Error analysis -> Analysis tool.Thank you very much.
David Cerdeira
