Thread: Standard recipe not exporting when configured as a Network
    11.01.2019
    2
    Default Standard recipe not exporting when configured as a Network
    Hello.
    I am sorry if this is very basic, but I have never used recipes before.
    I have a standard recipe which copies variable values to a .txt for comparisons purposes. The recipe is read and exported from functions on the screen and creates a .txt in an export folder in the RT.
    The process works when the project is configured as a standalone server configuration on my laptop, but not when I enable the network option in the project properties and transfer the RT files out to the devices.
    When the export function is trigger on the networked devices, the export folder is created in the RT, but there is no .txt.
    Is it possible to run the recipes when configured as a network? If so does anyone have any ideas what I am missing. I appreciate any help and support people could offer.
    Thank you
    Default Re: Standard recipe not exporting when configured as a Network
    Hello Username87,
    Please make sure you have unchecked the checkbox in "Do not generate and transfer" for the Standard Recipes in the "Runtime changeable data" settings in the project properties. Also please make sure that you have not renamed the recipes after you have configured the functions for recipe export.
    11.01.2019
    2
    Hello Mark,
    Thank you for the response and advice.
    Unchecking the "Do not generate and transfer" worked, thanks again.
  1. Replies: 4
    Last Post: 3rd May 2020, 14:10
  2. Exporting Report in .XLS
    Last Post: 28th June 2013, 10:59
  3. Exporting Array Variable
    Last Post: 6th June 2013, 13:07
  4. Standard Recipe - Retrieve name
    By marduv in forum zenon Supervisor
    Last Post: 1st August 2011, 15:49
  5. Standard Recipe and string variables
    Last Post: 5th May 2008, 09:43
