Thread: Zenon crashes while reloading
    28.03.2018
    54
    Default Zenon crashes while reloading
    Hi,"
    when ever I reload the project after editing the project its not freezing with 'Please wait-in progress" window. I tried un-reinstalling the software but no luck due to this I am not able to work on the project. Attached the log file
    Version 8.00 SP0 Build46644 32Bit
    Regards
    Sandy
    Attached Files Attached Files
    25.06.2012
    155
    Default Re: Zenon crashes while reloading
    Hello Sandy,
    for such sort of issue, I strongly recommend you to contact your local sales representative. In that case, please provide more detailed information such as:
    - type of the changes in the project performed in the Editor, e.g. Module + Change -> Variables: Modification.
    - does the project make use of API?
    - is it really a crash or a freeze of the runtime? Does the runtime recovers after becoming unresponsive? Is the OS also unresponsive?
    - SIC Full Log and project backup (if possible, so that we have the chance to try to reproduce the issue internally).
    Please note that the forum is not a suitable place to share sensitive information about your system or solution.
    Anyway, I took the chance to analyze the LOG file you kindly attached to this thread but unfortunately it does not contain relevant information.
    Thank you very much for your understanding.
    David Cerdeira
    28.03.2018
    54
    Hello David,
    Sorry I did not see the reply! Any changes such as variable edit,new function,new screen  has effect on reloading the editor. Runtime is fine only the editor will be showing "Please wait" and I have to kill it after waiting long time. I have sent a mail to support before a week and still no reply. I am posting here as I am getting quick reply from people like you
    thanks again
    Regards
    Sandy
    28.03.2018
    54
    I tried to uninstall everything including sql server and zenon editor, after re installing zenon I can not create projects as it is showing ZenDBSrv.exe not running on server localhost
    Sandy
    201
    Quote Originally Posted by sandeep2018;18411 [...
    I have sent a mail to support before a week and still no reply. I am posting here as I am getting quick reply from people like you [...]
    Dear Sandeep,
    have you recieved a ticket number? Only with that it is guaranteed that your inquiry has been received by the support team.
    If yes, please provide this number so I can check the actual status with the team and get back to you on the support channel.
    28.03.2018
    54
    Hello Felix,
    I replied to a ticket number-(TAT190819PHVC) this issue, I just tried to register again from the startup tool but the issue is still there. I can not see the ZenDBSrv.exe in the task manager.
    Regards
    Sandy
  1. Zenon editor crashes
    By sandeep2018 in forum zenon Supervisor
    Last Post: 26th August 2019, 15:42
  2. Runtimeservice Reloading - Event
    By carki in forum Add-In Framework
    Last Post: 12th February 2018, 13:09
  3. zenon Webclient crashes in Mozilla Firefox
    By ralff in forum zenon Network
    Last Post: 13th July 2015, 10:36
  4. Replies: 1
    Last Post: 1st April 2008, 11:58
  5. The zenOn Editor crashes at startup!
    By wolfgangm in forum zenon Supervisor
    Last Post: 13th August 2007, 16:16
