Showing results 1 to 8 of 8
Thread: Menu Bar in main project
    28.03.2018
    54
    Default Menu Bar in main project
    I have used the run time menus function to navigate through the integration projects. Is it possible to customize this menu window size and all as it is appearing in very small font in runtime system. The purpose is to navigate through the sub projects from the server only. Also sometimes the menus not visible
    Version 8.00 SP0 Build46644 32Bit
    Regards
    Sandy
    25.06.2012
    155
    Default Re: Menu Bar in main project
    Hello Sandy,
    The main menus are still available mostly for compatibility reasons, therefore their customization is quite limited compared to other actual zenon offered solutions that rely on the different screen elements available but also on all the possible screens/frames configurations.
    Documentation reference: Manual > Menus
    Anyway, while the menu window size is fixed, the text font of the menus can be configured when selecting a menu instance in the Menus detailed view.
    To navigate through different project screens (and projects) I would recommend you to follow the implementation of the Project Configuration Wizard that is started automatically when creating a new project in the Editor Workspace.
    This includes a navigation bar with multiple buttons that allow to open sub menus and can be fully configurable in terms of functionality but also graphically.
    I would also recommend to consult the DEMO project included when installing zenon for further inspiration.
    Good luck.
    David Cerdeira
    28.03.2018
    54
    Hello David,
    Thanks for sharing the info, currently I have added the mainproject "Overview" Screen in all sub projects and all subprojects "Main screen" button in overview screen this way I can navigate to all projects but to make the screen little more attractive i will try to use the method you suggested.
    Another issue with the alarm bar in main screen- ie I have configured the open alarm bar along with the main screen in all sub projects and it is working fine, there are some alarm filtering in screen switch function to get the current date alarms but operator need to switch the screen everyday to update the list. Any suggestion for this would help
    Regards
    Sandy
    25.06.2012
    155
    Hello Sandy,
    apart from other settings does the calling screen switch function that opens the AML screen has the flag below enabled?
    David Cerdeira
    28.03.2018
    54
    It was not enabled, Let me try this
    Regards
    sandy
    25.06.2012
    155
    Mr. Sandy,
    it must remain disabled so that the list is automatically refreshed.
    David Cerdeira
    28.03.2018
    54
    Dear David,
    It was already disabled, my issue is the time filtering as we need to display only current date alarms
    Regards
    Sandeep
    25.06.2012
    155
    Hello Sandy,
    Ok.
    In that case, please activate the option "Current alarms only" - Active: Only alarms that are still
    active, i.e. whose values are still in the critical range, are displayed.
    All the best,
    David Cerdeira
  1. Main menu height
    Last Post: 5th October 2016, 09:35
  2. Main menu
    Last Post: 30th August 2012, 09:40
  3. Main Menu VS Context Menu
    Last Post: 6th July 2011, 07:20
  4. Replies: 12
  5. alarm status line & Main menu
    By roberto1978 in forum zenon Supervisor
    Last Post: 23rd November 2010, 07:10
