Thread: zenon 6.20 project convert to 6.22 Version
    30.08.2018
    Beitrag zenon 6.20 project convert to 6.22 Version
    create  runtime  ,show   roject.mdb  file  will   be  not  overwritten,
    password.cmp  file  will  not  be  overwritten
    15.01.2016
    90
    Default Re: zenon 6.20 project convert to 6.22 Version
    Hello ludongyuan,
    If you upgrade your project to a newer version you have to compile the cmp files again, to do so open the project in your zenon editor and uncheck these check-boxes:
    then compile the project again.
    after compiling pleas don't forget to check this boxes again so it can not be overwritten by accident.
    Tobias Ritschel
  1. Convert Zenon project into Siemens ( Wincc / Wincc Flexible ) :-
    By ssmanku1699 in forum zenon Supervisor
    Last Post: 6th June 2018, 20:49
  2. integrste Workspace and Project source files in version control
    By francoisdevienne in forum zenon Supervisor
    Last Post: 12th April 2016, 09:12
  3. Advantage of ZenOn Energy version versus Standard version?
    By lephis in forum zenon Energy Edition
    Last Post: 23rd June 2011, 23:54
  4. Replies: 1
    Last Post: 18th November 2008, 12:12
  5. project needs to be converted although the same version was used?
    By markclemens in forum zenon Energy Edition
    Last Post: 19th November 2007, 11:27
