Thread: Facing error of command group even though variables available and linked properly
    04.03.2019
    Default Facing error of command group even though variables available and linked properly
    FACING ERROR  (RESPONSE VARIABLE DOES NOT EXIST) OF COMMAND GROUP EVEN THOUGH VARIABLES AVAILABLE AND LINKED PROPERLY.
    PFA Screen shot error
    891
    Default Re: Facing error of command group even though variables available and linked properly
    You probably forgot to link by variables, in the property: 'set value' - 'command group', the right Command Group.
    To claim to be "linked properly": as well the command group must know variable name patterns (e.g. "*_RV" and "*_CO")
    as each relevant variable must know its command group.
    04.03.2019
    it is linked correctly even though facing error
    891
    hmm, maybe send the project backup to your local COPA-DATA support for the diagnosis. If everything would be configured correctly, then there will be no error messages.
    Or try to reproduce the same in very small project - with only 1 response and 1 command variable and only 1 command group.
    It is strange that in those error messages the command processing writes all names of response variables with '*' (not resolved), while resolves the name of action variables.  How the command group definition - the action and the response variable settings - looks like? Maybe you are using '*' only in the setting of response variable, but not action? Then command processing does not know how to resolve this '*' (it assumes that variable name contains the '*' char).  The wildcard can work only if used in settings for as well name of action as response variables.
  1. Problem Facing on HTML5
    By AJAY KUMAR CHEKKA in forum zenon Supervisor
    Last Post: 29th April 2019, 09:28
  2. Replies: 2
    Last Post: 19th May 2018, 06:19
  3. Replies: 0
    Last Post: 18th May 2015, 14:48
  4. Replies: 1
    Last Post: 24th June 2014, 19:51
  5. Search Variables & linked Objects
    By derda in forum zenon Supervisor
    Last Post: 3rd February 2011, 00:36
