Thread: Alarms sound
    30.03.2017
    8
    Default Alarms sound
    Dear,
    You have some questions regarding the sound for alarms, the version of zenon used is 7.10
    First is a project and its subproject:
    The project is a central A and the subproject is a central B.
    What the client requests is the following:
    The sound of the alarms between the exchanges must be differentiated, that is possible with the function, but the sound of the last alarm always remains, for example if the last one was an alarm of the central A only sound A will be heard, and if then an alarm occurs in the central B, only the sound B will be heard. They want is that both sounds can be heard and that the sound can be stopped independently, I mean that with a button you can stop the sound A and with another the sound B.
    It is possible to make this configuration and in what way or in any case if this can be done only with a last version of Zenon indicate it.
    25.06.2012
    155
    Default Re: Alarms sound
    Dear walt24m,
    Thank you very much for your post.
    Please find a solution based in zenon Logic running on the two projects.
    In this case, zenon Logic monitors if there are active alarms on two areas (Central A && Central B) and toggles the respective PlayTone variable to execute "Play audio file" in both areas "simultaneously" by limit. In this solution the two alarm sounds can be played/stopped independently.
    For play with the project, simply start the runtime of CENTRAL A (+ CENTRAL B) project and trigger/halt the alarms of the respective areas.
    Good luck.
    All the best,
    David Cerdeira
  1. Alarm Sound bei Störmeldung
    By crz in forum zenon Supervisor
    Last Post: 16th August 2018, 08:10
  2. 02 different Alarm Sound
    By skywalker in forum zenon Supervisor
    Last Post: 29th June 2016, 03:30
  3. Alarms in RUN-TIME
    By matteo.fabbri in forum VSTA
    Last Post: 8th March 2014, 17:38
  4. Number of Alarms.
    Last Post: 20th December 2013, 12:30
  5. acknowledgment alarms
    By andoni in forum zenon Energy Edition
    Last Post: 26th April 2013, 00:41
