Thread: Problems with multiuser mode
    20.03.2017
    8
    Default Problems with multiuser mode
    I have a very serious problem with variable administration in a multi-user project. I don't use VPN to connect with multiuser server, I'm in the same network.
    When I click: exclusive access to the entire variable administration, I take control of all variables but at the end clicking "Accept changes" I get this error: "An error occurred while checking in elements". Restart of editor doesn't help, the only thing that works is removing from local.ini file: "[MU_MODULE] VARIABLES=2" and after doing it I can discard changes (and lost all new added elements) but still can't accept changes. It means that I'm not able to work via zenon because all the changes don't save.
    Do you have any idea how I could solve this problem?
    Thanks in advance for your help!
    Łukasz
    07.08.2018
    10
    Default Re: Problems with multiuser mode
    Hi Łukasz,
    This is an inconsistency in the database, probably because the project has been updated several times. There to correct an already updated database, in any case, the server database must be updated and all local databases, which can also be easily deleted and recreated. Or maybe
    try to uninstall and reinstall zenon and uninstall and reinstall SQL 2012 via the "AdditionalSoftware" folder in the ISO. But don't forget makes backup from your project before uninstall.
    King regards,
    20.03.2017
    8
    thank you very much for you reply. I was trying to reinstall zenon and SQL 2012 many times and it didn't help. Finally with Copa Data support we have found the solution. It was enough to turn off the windows firewall and everything started working right away.
    Cheers,
    Łukasz
  1. how to vsta mode change
    By backjahyun in forum VSTA
    Last Post: 16th May 2016, 01:08
  2. Zenon MultiUser issue
    By mmiencu in forum zenon Supervisor
    Last Post: 25th August 2015, 14:43
  3. multiuser project check in not possible (SQL error)
    By simsuniy in forum zenon Supervisor
    Last Post: 14th January 2015, 11:22
  4. Analyzer und Multiuser-Projekt
    By michab in forum zenon Analyzer
    Last Post: 3rd January 2014, 13:57
  5. webclient 7.0 in virtual xp mode
    By michab in forum Webserver / Webclient Setup
    Last Post: 26th July 2013, 10:54
