Thread: Visual Studio, Config files and Zenon 7.6/8.0
    04.09.2019
    16
    Default Visual Studio, Config files and Zenon 7.6/8.0
    I have an app.config file which i use in my addin project.
    I am building my addin with visual studio and have set the
    properties of the app.config to copy always.
    When I build with Zenon 7.6 as reference in the project. The file is copied to the bin/Debug directory and renamed
    library.dll.xml. However when i unzip the addin, the config file is not included.
    Now interestingly if I use Zenon 8.0 as reference and do the same procedure, the app.config is renamed
    and put in the output directory, the config file is included in the scada addin.
    I dont know how visual studio uses the copa data developer tools  and zenon version as reference.
    I would like this to work using both zenon 7.6 and 8.0, any thought about this or is there any known
    problems using 7.6 zenon with visual studio and config files ?
    thanks,
    roger
    04.09.2019
    16
    Default Re: Visual Studio, Config files and Zenon 7.6/8.0
    I have removed the Zenon 8.0 from my computer and
    the system seems to work fine now. VS 2017 with config
    file seems to properly form the add in.
  1. Report-Visual Studio
    By MotionEngineering in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 4th June 2021, 08:26
  2. AddIns and config files
    By roger_novarctech in forum Add-In Framework
    Last Post: 1st November 2019, 23:21
  3. Variable Change Event vb.net Visual Studio 2015
    By Thomas.Jahn in forum Add-In Framework
    Last Post: 2nd September 2019, 09:35
  4. web server zenon config location
    By eden212 in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 23rd January 2018, 12:54
  5. UnitTests in Visual Studio 2017
    By mmatanovic in forum Add-In Framework
    Last Post: 21st December 2017, 12:59
