Thread: Network Authorization for Users
    03.04.2018
    Default Network Authorization for Users
    Hi
    I have a total of 4 systems in a network, I would like to block the execution of breaker commands from the other 3 and only assign oneSystem for the execution. How do I use Network Authorization or is there any other way I can achieve this?
    All the 4 systems use more or less the same Database.
    Regards
    Joyel Jose
    1,107
    Default Re: Network Authorization for Users
    Are you using the zenon Network? so when you talk about "4 systems in a network", do you mean one zenon project running on a network server PC and 4(?) additional PCs which are network clients?
    And if not, so you have 4 different zenon projects (?) running in the same network and controlling the same IEDs (devices) - why like this? Why not the zenon network?
    In zenon Network, the module Command Processing takes care automatically to allow command actions on a particular switch (represented by response variable) only from one network client. This handling bases on status bit NET_SEL (more in zenon help: Manual > Status processing > Status bits > Selected in the network [NET_SEL]). In additional you can use 'Authorization in the network' feature if you want to prevent the operation on the whole feeder bay while one operator controls one of switches there (more in Manual > Network > Authorization in the network).
    If those "4 systems" are not all zenon, but from different manufactures, then the only way to exclude parallel operations would be some kind of interlocking or additional data points with info about running commands - implemented in IEDs (in devices); because only this would synchronize the information for all controling systems.
  1. Linking Users to corporate Domain account
    By Xavier in forum zenon Energy Edition
    Last Post: 18th July 2019, 08:04
  2. Widows users with Process Gateway
    By yara in forum Gateways
    Last Post: 8th September 2015, 07:47
  3. Managing Users settings in Zenon Runtime
    By daujivar in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 6th August 2014, 12:43
  4. Analyzer users out there?
    By stadtschnitzer in forum Report Engine (former zenon Analyzer)
    Last Post: 3rd January 2014, 12:50
  5. Active Directory users do not have correct userlevel
    Last Post: 4th June 2007, 13:22
