Thread: Zenon client/server issue
    15.02.2019
    6
    Default Zenon client/server issue
    I am using the Zenon 7.6 Energy edition with 2 computers,1 acting as server and the other as client. I'm facing issues where there appears to be some synchronisation issue between the client and server. Some of the graphics and coloring for annunciation screens which are in the Server is not getting reflected in the Client.(for eg;when a signal goes high and the annunciation window goes red in the server, this is not reflected in the client, but the signal change is reflected in Alarm and event list in the client)
    I've already checked the transport settings and ensured that any change in data at the server is getting updated in the client as well.
    Please let me know if you need any more information.
    I have already generated new runtime files, reinstalled Zenon and even changed the path of Runtime folder.
    947
    Default Re: Zenon client/server issue
    maybe some graphical design is made in project basing on Internal variables? The variables from INTERNAL driver have setting to be local on each computer, or Network variables. Make sure those internal variables which are color indicators from alarms etc. are all configured to be calculated in the Network, not local.
  1. Remote OPC DA Server with Zenon OPC Client
    By jose.torres@indexum.com in forum Drivers
    Last Post: 1st April 2020, 14:38
  2. Zenon OPC UA Server Issue
    By Praveen Kumar Karthikeyan in forum straton / zenon Logic
    Last Post: 21st May 2019, 09:43
  3. Zenon Server-Client RT Licensing
    By emrocon in forum zenon Network
    Last Post: 16th August 2017, 16:17
  4. Zenon OPC Server Issue
    By shikra in forum Drivers
    Last Post: 29th May 2012, 01:31
  5. zenon server acting as a client
    By hoscillada in forum zenon Energy Edition
    Last Post: 7th January 2010, 07:42
