Thread: Error VBE6EXT.OLB
    19.11.2018
    Default Error VBE6EXT.OLB
    In my customers PC zenon supervisor 7.20 RT was installed. Everything was fine until they uninstalled Microsoft Office. From then VBE6EXT.OLB error was generated.
    Please, resolve the issue.
    25.06.2012
    155
    Default Re: Error VBE6EXT.OLB
    Dear SUSANTH_p,
    Welcome to the COPA-DATA Forum.
    Please start the following installers from the zenon 7.20 setup medium:
    Good luck.
    David Cerdeira
    Last edited by david.cerdeira : 26th July 2019 at 11:52 Reason: Improved picture quality.
    19.11.2018
    Dear David Cerdeira,
    Thank you for your prompt response, can you please brief me regarding the error because i need to justify it to the customer.
    25.06.2012
    155
    Dear,
    it is exactly what you state on the first message: The Microsoft Office uninstaller removed Visual Basic For Applications (VBA) from the PC and unregistered related classes, when it shouldn't as other software, like zenon, depend on the same libraries/classes. This is a know "problem" of some applications.
    Just for your personal knowledge, if you unzip the Vba71.msi file (e.g. using 7-zip) you can immediately find the file you were looking for.
    David Cerdeira
    19.11.2018
    I installed Microsoft Visual Basic and the language packs as you directed. But still the same error is coming when we start Zenon RT.
    25.06.2012
    155
    Dear,
    Do you still see the same error message?
    In a Microsoft forum you can find a possible solution: Link.
    If the issue persists, then I would strongly recommend you to contact your local support representative.
    Thank you very much.
    David Cerdeira
    17.02.2020
    I encountered the same problem ("VBE6EXT.OLB could not be loaded") on a computer with zenon supervisor 7.60.
    In the link david.cerdeira posted on 29th Jul 2019 I found a reference to registry key HKCR\Typelib\{0002E157-0000-0000-C000-000000000046}
    This registry key was missing on the computer where the problem occured.
    I exported the registry from some other zenon 7.60 computer and imported it to the malfunctioning one. => problem solved.
    Wilfried
  1. Replies: 2
    Last Post: 19th May 2018, 06:19
