Showing results 1 to 10 of 10
Thread: Ctrl+Alt+R and Ctrl+Alt+D Shortcuts not working
    Default Ctrl+Alt+R and Ctrl+Alt+D Shortcuts not working
    I am using zenon 7.60, From my editor i unable to open RT folder and Data folder using the Shortcuts Ctrl+Alt+R and Ctrl+Alt+D respectively.
    kindly advice.
    Regards
    SwamyP
    808
    Default Re: Ctrl+Alt+R and Ctrl+Alt+D Shortcuts not working
    Before use the shortcuts place the cursor on the name of the project (in the project tree on the left). If your cursor is somewhere else, e.g. in the variable list or on a screen etc., then those shortcuts are deactivated (to avoid ev. conflicts with other shortcuts).
    808
    And... make sure that on this PC with Editor you have already at least once compiled the project (so the RT folder exists) and started the Runtime (so the data folder exists too). Else only the shortcut Atl+Ctrl+E will work.
    It does not work if Runtime runs on another computer as your Editor.
    Hello team,
    1)Before using the shortcuts i have clicked on project name(project is activated).
    2)Also run time files are created.
    But still i am facing the issue.
    SwamyP
    808
    if project is activated or not does not matter, only the cursor position in the Workspace. Is the Alt+Ctrl+E also inhibited? What build of 7.60 are you using?
    Ctrl+Alt+E is working.
    I am using build54483.
    SwamyP
    808
    I've check in exactly this build that on my PC (Windows 10) all project shortcuts are working correctly.
    Do you have in project settings the defaults in 'Runtime folder' (a subfolder in public documents) and 'Data folder' (default empty - means subfolder in public documents too)?
    like on my screenshot:
    do you have (as Windows user) access to the RT directories (can you see the RT directory if you browse HDD manually in Windows Explorer)?
    Yes, the settings are default as shown in the screen shot. Also i would like to mention we face the same issue with 7.50 version also
    Yes, I am able browse manually in Windows Explorer
    808
    So it would be something specific to your combination of operating system version (updates?) and maybe some installation problems or combination with other installed programs, hard to say. When Ctrl+Alt+E works but other shortcuts not - and all 3 shortcuts are in one functionality, the only difference is the parametr with path - so maybe some other application on this PC catches/overrides some shortcuts?
    Hello Team,
    Thank you for advice.We will check.
    Regards
    SwamyP
  1. Allocations not working
    By knubla in forum zenon Supervisor
    Last Post: 3rd June 2014, 12:24
  2. zenkeyblock & Ctrl-Alt-Del
    By tauhien in forum zenon Supervisor
    Last Post: 14th July 2008, 07:24
  3. Working with 'OnlineVariables'
    By robertf in forum VBA
    Last Post: 16th April 2008, 16:26
  4. Working with REMAs
    Last Post: 13th September 2007, 14:29
  5. Working with the 'CEL' objects
    Last Post: 16th August 2007, 09:20
