Thread: Red blocks
    09.04.2019
    7
    Default Red blocks
    When i navigate in the SCADA-application it cost time to load some objects. This shown bij a red figure next tot the icon. Is there a way to speed up Zenon?
    23.11.2016
    10
    Default Re: Red blocks
    Can you be a little bit more specific?
    A slow runtime can be the result of many problems:
    - misconfigured archives
    - misbehaving API code
    - ...etc.
    Furthermore your title says "red blocks", are you may having trouble with your driver?
    BR
    09.04.2019
    7
       This is a screenshot of the red block.  If Start run time this is what Zenon show in every image or numeric box. it just appears for a second
    Hi JohnBar,
    The red square or red block, can be an indication for the variable status "INVALID". This variable status is set by the driver, when a communication error has occurred. Communication errors can occur for various reasons. Communication errors can result in a delayed response or in a delayed update of the variables displayed in the screen. Especially if variables are only used in screens and the driver is in a timeout waiting for a response from the PLC.
    The red square can also be an indication that the driver is stopped. This would be specific to your project.
    I'd suggest reviewing the logs of the diagnosis server, utilizing the zenon diagnosis viewer, to establish if there are in fact communication errors. If there are errors in the communication, establish the reason and try to resolve these.
  1. IEC61850 Driver - Report control blocks - Communication Problem
    By andrea.ornago in forum zenon Service Engine Operator
    Last Post: 24th October 2017, 10:40
  2. [CE6] Grafic File blocks Remote Transport
    By steven.costantini in forum zenon Service Engine Operator
    Last Post: 27th November 2015, 14:28
  3. Functionalities of ALARM-blocks in Logic
    By croc in forum Engineering Studio Logic & Logic Service (former zenon Logic Workbench & Runtime)
    Last Post: 27th February 2015, 14:33
  4. Runtime completely blocks right at the start
    Last Post: 30th April 2011, 15:21
