Thread: Right Click continuously button for a multi touch
    13.02.2019
    30
    Default Right Click continuously button for a multi touch
    I would like to insert in my project (for a multi-touch panel) a button that simulate continuously right click if stay pressed.
    I found only a function that if I press on button , the next click is a right click... But I have to press on it everytimes I need a right click... I can't take it pressed.
    How I can do that?
    Thanks everyone
    Default Re: Right Click continuously button for a multi touch
    Hi doublem,
    Have a look at the mouse / touch screen driver settings to see if there is an option that will enable a right click when pressing and holding the screen. Often this is offered by drivers and can be configured.
    13.02.2019
    30
    Yes, the mouse working on stay pressed for right click but only on windows setting (for example on a right-click folder) but in zenon is not recognized.
    I have a button with a VBA Macros "Right Click" and if the touchscreen stay long pressed, the right click isn't recognize on this element.
    845
    maybe your VBA is not calling the original event? e.g. like:
      obElem.RightClickDown
    13.02.2019
    30
    It's a simple Context Menu and isn't recongnize by a long press of the touchscreen (with the right click of mouse everything works perfectly!)
  1. Multi-touch demo project
    By i.sabbonis in forum zenon Supervisor
    Last Post: 27th January 2017, 13:39
  2. Zenon Touch V5.50
    By eddymar in forum zenon Operator
    Last Post: 21st August 2015, 10:33
  3. Button Click Event in VSTA Windows Form
    By parthbdesai in forum VSTA
    Last Post: 20th August 2015, 05:20
  4. Multi-Indicator Button
    By dlamarche in forum zenon Supervisor
    Last Post: 25th July 2013, 21:10
  5. Right Click issue
    By whitetaru in forum VBA
    Last Post: 26th April 2011, 06:46
