Thread: Report Viewer Export/Print won't work
    29.10.2018
    Default Report Viewer Export/Print won't work
    Hi All,
    Since we have upgraded Windows on our server, I have a problem with Report Viewer Export/Print function.
    I am using it in two ways. Once to generate AML Report and once for generating report of actual values.
    I attached DiagViewer logs and screen from it generated when function starts.
    Can anybody tell me, how can I solve it?
    Loading backup on server is not possible.
    Arek
    Edit:
    I am using Zenon 8.00 SP 0 Build 53129
    25.06.2012
    155
    Default Re: Report Viewer Export/Print won't work
    Dear aremus1,
    Welcome to COPA-DATA Forum.
    Without having more detailed information, please have a look in the editor for the function responsible of the report file export. This should be the type "Report Viewer: Export/print".
    Make sure the target file name and path are valid and can be written in the target OS. If the file path is set by a zenon variable, make sure this contains a valid pathname for the report output.
    If still this does not help, please contact your local support team so that you get further help.
    Good luck.
    David Cerdeira
  1. .rdl file (Report Viewer) shall open in Report Builder
    By its_me in forum zenon Supervisor
    Last Post: 4th October 2018, 05:16
  2. Multiple columns in Report Viewer report
    Last Post: 29th May 2017, 13:23
  3. Report Generation - Print .ARX pdf
    By leeyitli in forum zenon Supervisor
    Last Post: 20th January 2017, 10:52
  4. Report Viewer Pdf Export
    By Florian L. in forum zenon Supervisor
    Last Post: 7th November 2016, 14:54
  5. Replies: 2
    Last Post: 24th August 2011, 08:22
