Thread: Data extraction using function code 14
    11.02.2019
    21
    Default Data extraction using function code 14
    Hi, does anyone have any experience on using function code 14(read general reference) to extract data from a meter? Can share about the steps and software used to extract the data?
    Zenon have a function that can send specific command(driver command) to selected driver, is this can be used to get the data? Thanks
    765
    Default Re: Data extraction using function code 14
    hmm, "function code 14" but in which communication protocol?
    zenon functions 'driver commands' are typically to control the driver, not to send commands to a PLC. It depends on driver, but typically in drivers supporting write (command) direction - to send a command you have to create variable (and configure its addressing settings correctly) and then set a value to the variable.
    11.02.2019
    21
    Communication Protocol- TCP/IP or Modbus RTU
    For normal condition, we can choose in software either holding or input register of the devices by inserting the correct register address stated on the datasheet in order to get data. However, how to read the data through function code 14 even I have the register address? Any software have the option to read the general address?
    Thanks.
    765
    In the official MODBUS protocol specification (see http://www.modbus.org/specs.php) there is no function code 14; not decimal. Could it be that this "14" is hexadecimal - 0x14? Then decimal 20 - "Read File Record" function; very specific function supported in MODBUS_Energy driver.
    zenon MODBUS drivers - MODRTU und MOBDUS_Energy - are supporting only officially known function codes.
  1. Extraction of Files through IEC 101
    By abhilash in forum zenon Energy Edition
    Last Post: 26th June 2017, 10:53
  2. Extraction of Files through IEC 101
    By abhilash in forum Drivers
    Last Post: 26th June 2017, 08:10
  3. IEC 61850 disturbance file extraction
    By ansab.tp in forum Drivers
    Last Post: 16th April 2013, 07:28
  4. Replies: 3
    Last Post: 24th May 2011, 13:00
  5. function "Export Data" on Windows CE
    Last Post: 20th August 2007, 07:01
