Originally Posted by
douglasm
I have installed a runtime version of Zenon onto a windows Xp Sp3 laptop, the zenon version is 6.22 SP1.
when I start the machine I recieve the error message shown in the attachment
This is the first time I have seen this error as I have installed the runtime on other computers and this has not occurred.
Additionally there is a third party application installed on the laptop which is called on startup of windows which I assume to be conflicting with the zenon application
the zenon application is not called at startup. I was hoping that there would be some way of preventing the zenSysSrv.exe from being called until the other application has fully loaded.
thanks
Compatibility mode is a useful feature that allows you to run old applications on your PC. However, this feature can sometimes cause Microsoft Visual C++ Runtime Error to appear. To fix the problem, you need to disable Compatibility mode
check for other methods here:
https://www.errorsolutions.tech/error/microsoft-visual-c-runtime-library-error/
