Thread: IEC104 General Interorgation
    Default IEC104 General Interorgation
    Hi
    I need to send command GI from Zenon 104 master per hour. In manual that "By creating command execute with TYPE=100, QULIFIER=20 (VALUE=TRUE or FALSE), you can start a general interrogation manually " so this is in command processing. But it can not assign to time control. Is a function to send command processing ?
    Brgds
    879
    Default Re: IEC104 General Interorgation
    Create a variable with type ID 100. Then create a zenon function 'write set value' linked to your T100 variable and set value 1 with 'direct to Hardware' option. Then link this function in the Time Control module.
    To process GI you do not need the Command Processing module (as there is no particular response variable there).
  1. Befehlsgabe Doppelsignal IEC104
    By axel in forum zenon Energy Edition
    Last Post: 17th July 2018, 15:00
  2. Step Position with IEC104
    By djgaunt in forum Drivers
    Last Post: 29th January 2018, 11:57
  3. Hardware Requirements (General)
    Last Post: 15th January 2015, 20:09
  4. General Report
    By natali in forum zenon Supervisor
    Last Post: 19th February 2013, 15:39
