Thread: reload driver
    25.09.2009
    38
    Default reload driver
    Hello
    how to set settings that after start, stop IEC 101-104 driver procedure SCADA remember last used values and status bits (AVALUE.....)
    845
    Default Re: reload driver
    Why do you need it?
    Why you want to stop/start the iec870 driver and you don't want to have in your variables that was comes after re-connect from General Interrogation? Each kommunication start in IEC 60870 Standard demands a GI at first.
    25.09.2009
    38
    we have 2 gateways, we every second check ping and no ping we restart driver with another IP address, but if we set some point in (AVALUE=1) after driverl reload we have (AVALUE = 0)
    25.09.2009
    38
    it is impossible not stop driver but only change IP address?
    845
    As I remember you are switching TCP/IP configuration of the driver to secondary IP (of the same end-device) to manually shorter switch-over timeout by communications problems.
    So you are intentionally not using redundancy mechanism build in the driver.
    It is the consequence - you are losing some status bits. I will thing over how to help you, but I need time.
    But I think, the simplest would be to keep using secondary IP in driver configuration.
  1. Replies: 3
