Thread: Cycle read file
    27.08.2015
    8
    Default Cycle read file
    Hi All,
    I use this code to read data from a file:
    The first time I run, It's correct, like this:
    I saw that the ID1 increase step by step, and then when ID1=32 then return to 0, it's not correct, like this:
    Could you please help me to solve this.
    Attached Thumbnails Attached Thumbnails 2019-06-04_193141.png   2019-06-04_192858.png
    810
    Default Re: Cycle read file
    Open the file only once, and not in each cycle. Then use this (single) ID as long as file is open.
    In each cycle you then can read the next line.
    And when you finished to read (all) lines - close the file, e.g.:
    #define fNull 0
    if fileID = fNull then
    fileID := F_ROPEN (FPATH);
    end_if;
    if fileID <> fNull then
    if not F_EOF( fileID ) then
    lineText := FM_READ( fileID );
    (* file line evaluation - to variable value and timestamp
    else // file completed - close file
    F_CLOSE( fileID );
    fileID := fNull;
    end_if;
    end_if;
    Last edited by ursulak : 5th June 2019 at 09:40 Reason: corrected to 1 cycle process
  1. Can zenon read data from a *.csv file
    By kieuminh in forum zenon Supervisor
    Last Post: 23rd May 2019, 12:40
  2. Can zenon read data from a *.csv file
    By kieuminh in forum zenon Energy Edition
    Last Post: 15th May 2019, 17:04
  3. Replies: 1
  4. Replies: 2
  5. Archive scanning cycle ignored
    By nsko in forum zenon Supervisor
    Last Post: 18th August 2008, 14:03
