Thread: Windows Key Lock for operator.
    04.01.2019
    Ausrufezeichen Windows Key Lock for operator.
    Hi all,
    I need to disable windows key as well as ctrl+alt+del function for operator  but for the admin login he should be able to access these keys.
    25.06.2012
    109
    Default Re: Windows Key Lock for operator.
    Hello nivish,
    thank you very much for your post.
    I am not an expert on Windows users, but when integrating zenon user administration with Active Directory, I believe you can define those kind of rules based on the user logged-in in the group policy settings.
    There are other possibilities based on batch files or manipulating Windows registry keys but this of course must be implemented on your own risk. Try to google a bit.
    Maybe someone else has a better idea to help you.
    Good luck.
    David Cerdeira
  1. Zenon Operator freeze
    By danyr in forum zenon Operator
    Last Post: 16th April 2019, 12:04
  2. Operator screen
    By sandeep2018 in forum zenon Operator
    Last Post: 28th January 2019, 12:05
  3. Webserver with Zenon Operator
    By joelprasad in forum Webserver / Webclient Setup
    Last Post: 5th September 2018, 09:21
  4. Operator Warnings
    By philippevdt in forum zenon Energy Edition
    Last Post: 27th November 2015, 14:22
  5. Use of Zénon Operator ?
    By florian in forum zenon Operator
    Last Post: 9th June 2015, 12:51
