Thread: Reading Values with the DDE-Driver from Excel
    08.05.2019
    2
    Default Reading Values with the DDE-Driver from Excel
    Hi!
    I am trying to read a column from an Excel-table into an array in zenon. In order to do that I created a DDE-Client-driver and a DDE-variable.
    Server: EXCEL
    Topic: [AUFTRAG.XLSX]SHEET1
    Item: R1C1:R8C1
    Then I imported the variable from the driver as an SPS Memory Object and String as Datatype. When I try to display the value of the variable in the runtime with the dynamic text element - nothing gets displayed. (I also tried to display a singel cell with Item:R1C1, but I also got no value displayed in zenon).
    If I import my DDE-Driver settings in Excel I can however write values from zenon to Excel. But as stated before, reading values does not work for me.
    I hope you can help me with!
    985
    Default Re: Reading Values with the DDE-Driver from Excel
    maybe your dynamic text element is configured to display the variable "limit value text" and not the value?
    08.05.2019
    2
    No it's configured to display the Variable value.
    I just saw, that Copa-Data developed an Excel-macro for variable import. Is it possible to share this file with me?
  1. Need help: Create driver variable from an excel rows sheet
    By marcomauri in forum zenon Energy Edition
    Last Post: 31st January 2019, 04:59
  2. Updating Values of variables in Scada from Excel
    By jonastj in forum zenon Service Engine Supervisor
    Last Post: 3rd February 2015, 14:35
  3. Status: INVALID , NT_870 but reading values
    By geleto021 in forum zenon Energy Edition
    Last Post: 1st April 2014, 09:46
  4. Updating Values from Scada to Excel
    By sidramsatyal in forum zenon Service Engine Supervisor
    Last Post: 10th January 2014, 18:49
  5. Reading Excel
    Last Post: 27th September 2013, 17:09
