Thread: IEC 60870-5-101 Line Redundancy
    07.05.2018
    21
    Default IEC 60870-5-101 Line Redundancy
    We are designing a SCADA system for substation with Zenon Energy Edition V8.0. Client wants that, SCADA will get signals from field devices with IEC60870-5-101 protocol. There are 2 serial ports on the computer and also field devices have 2 serial ports. If one of the line is broken, the other one will continue to communicate with SCADA.
    Line redundancy is possible with Zenon?
    Thanks.
Name:	Communication Layout.png
    25.06.2012
    155
    Default Re: IEC 60870-5-101 Line Redundancy
    Hello Konsistek,
    welcome to COPA-DATA Forum.
    In this case, I would use the COPA-DATA Alternative Datapoints Driver, as the ADP driver allows to configure variables that can receive values from different sources, such as variables from the same or different drivers (e.g. IEC870). With the help of a selector variable it is possible to select the variable which will be linked.
    In this specific case, I would configure two IEC870 drivers, which assigned to the respective line (COM), and use the ADP driver to toggle between the two connections based on the rules needed (e.g. redundancy).
    You can find the ADP documentation in zenon help topic Drivers > ADP.
    I hope this helps you.
    David Cerdeira
  1. Redundancy errors
    By diemon in forum zenon Network
    Last Post: 2nd April 2015, 08:17
  2. set up servers for redundancy
    By hajjsaid99 in forum zenon Network
    Last Post: 13th March 2015, 12:20
  3. Redundancy issues
    By k_r_mehta in forum zenon Network
    Last Post: 29th August 2013, 05:12
  4. Server redundancy
    By tauhien in forum zenon Network
    Last Post: 27th May 2011, 00:21
  5. PLC redundancy
    By gyu in forum Drivers
    Last Post: 17th May 2011, 05:29
