Thread: MATHDR32 counter variable problem
    28.02.2017
    5
    Default MATHDR32 counter variable problem
    We have system with 2 redundant servers ver. 7.0 and 2 clients. We count working hours for few machines using MATHDR32 variables that are recorded in historian. After a accidental power loss the servers restart and some (not all) of the counter variables changed their value. For example one of the variables went from 974 to 128 (this change is recorded in archive). What have gone wrong?
    831
    Default Re: MATHDR32 counter variable problem
    The MATH driver is running only on process server (and not on standby server). Thus, the redundancy switch may result in a different MATH variable value if it is calculated basing on a local (not network) source variable.
  1. Counter for Online Value
    By fatih.oz in forum VBA
    Last Post: 22nd September 2014, 16:53
  2. Counter
    By fatih.oz in forum zenon Supervisor
    Last Post: 17th September 2014, 08:10
  3. Reset of counter variables
    By roberto1978 in forum VBA
    Last Post: 20th June 2011, 10:40
  4. MATHDR32 mathematics drive is too weak?
    By lephis in forum Drivers
    Last Post: 27th May 2010, 13:33
  5. How to create a "Time Counter" variable?
    By lephis in forum zenon Supervisor
    Last Post: 24th August 2009, 11:17
