Thread: Execute Function Block in Straton
    14.09.2017
    12
    Default Execute Function Block in Straton
    What is the role of execute block in Straton?
    Can we provide command (e.g. T45 COA=1, IOA-2) without using command processing window if we use this block in straton?
    Rahul I.
    23.10.2018
    10
    Default Re: Execute Function Block in Straton
    Yes with the help of the IEC60870_SELECT and IEC60870_EXEC blocks in zenon Logic, you can send commands to an IEC60870-104 Server (or -101 Slave)
    There is some information in the Online Help (select the block and press F1) and in the zenon Logic Help > Tutorials > Protocols > IEC60870-5-10-104 Master
    Anthony
  1. canOpen coWriteParam function block
    By mos89 in forum straton / zenon Logic
    Last Post: 7th June 2018, 11:39
  2. Developping C function block
    By kwangyol in forum straton / zenon Logic
    Last Post: 29th March 2017, 10:26
  3. Execute function Export archive automatically
    By jahidbagwan in forum zenon Supervisor
    Last Post: 8th September 2014, 12:02
  4. Execute a Function on changes of a Float Variable
    By mcavdar in forum zenon Supervisor
    Last Post: 9th January 2013, 13:43
  5. Execute function in VBA
    By focus in forum VBA
    Last Post: 17th January 2012, 15:17
