Thread: Zenon Trending Issues
    11.02.2019
    23
    Default Zenon Trending Issues
    Hi, I curious about the Zenon historian function. Hope someone can enlighten me.
    1. I have set a historian for a variable let's said variable A with cyclic 1 min. Save cycle is 1 day.
    2. Then I have set another historian for same variable under user-defined function to start and stop archive. Save cycle is 14 hours.
    Here my questions, would the historian of number one will be deleted when I have setting up number 2 and reload Runtime online?
    Let's said I have done the setting for number 2 and reload the Runtime at 1400 hours  20 May, would the historian for number 1 will deleted or disappear for 19 May at 1400 hours until 1400 hours 20 May. What I meant is would the system couldn't record the data or save the data if I reload Runtime online before the save cycle time.
    25.06.2012
    157
    Default Re: Zenon Trending Issues
    Dear shaun,
    thank you for your post.
    In general, configuring a new or other archive does not influence other existing archives, even if they are running already in the runtime.
    1 and 2 archives are different and independent archives, therefore the configurations applied to 2) have no effect on 1) in the runtime.
    Please note that although the same variable is present in both archives, this only means that the variable will be archived twice using different archive parameters.
    I hope this answer helps you.
    David Cerdeira
  1. Zenon Trending Graph
    By shaun in forum zenon Supervisor
    Last Post: 14th May 2019, 07:49
  2. Zenon Trending Configuration
    Last Post: 9th May 2019, 02:57
  3. Tab navigation issues
    By HMIdeveloper123 in forum zenon Supervisor
    Last Post: 15th February 2017, 16:30
  4. Redundancy issues
    By k_r_mehta in forum zenon Network
    Last Post: 29th August 2013, 05:12
  5. Trending
    Last Post: 29th April 2010, 05:17
