Thread: Difference Between testBit/setBit and variable.bitNumber
    08.05.2018
    6
    Frage Difference Between testBit/setBit and variable.bitNumber
    Hi ,
    Suppose that i have a word variable like xWord (which is imported from OPC server) and i want to read or set some of its bits.(in following example, xbit is an internal zenon variable which is visible in Scada Logic) What's the difference between following approaches ? :
    1- xbit1  :=testBit(xWord ,1);  //(For reading second bit or bit number 1 )
        xWord := setBit(xWord,2, xbit2); //(For setting third bit or bit number 2 of xWord. This should change value of original xWord variable on the OPC and PLC)
        or :
    2-xbit1 := xWord.1 ;
       xWord.2 = xbit2 ;
    Thank you!
    831
    Default Re: Difference Between testBit/setBit and variable.bitNumber
    In case of your code - calling the FBs *Bit with a constant in the input BIT - there is no difference.
    The FBs *Bit are useful in the scenario when BIT input is a dynamical value (in a variable), and not a fix constant.
  1. 1. Modify BitAddr of variable, 2. edit SubItems of variable
    By professor_hubert_farnsworth in forum VSTA
    Last Post: 18th January 2017, 09:46
  2. Difference bewteen stratonng variables
    By DavidMarek in forum straton / zenon Logic
    Last Post: 1st March 2016, 13:05
  3. Replies: 1
