Thread: Webserver Routing & Redundancy
    10.05.2017
    68
    Frage Webserver Routing & Redundancy
    Hello Team,
    I have a primary and redundant PC. I would be using Webserver upto 20 Concurrent clients. In order to achieve redundancy do I need to procure two licenses of Webserver and install at both servers or can I buy a single license of Webserver and install it on a third PC(routing) and achieve redundancy.
    Kindly advice
    Thank You
    Joel
    163
    Default Re: Webserver Routing & Redundancy
    both scenarios are possible.
    Depending on if you only want to monitor or also operate through the webclients you will need to purhcase zenon Web Server or zenon Web Server Pro.
    There is also an explanation in our manual in the section "zenon Web Server", if you have zenon installed.
    10.05.2017
    68
    Daumen hoch Re: Webserver Routing & Redundancy
    Quote Originally Posted by felixst View Post
    Thank You Felix
    Joel
  1. Redundancy & HTML5
    By joelprasad in forum HTML5 Configuration
    Last Post: 5th August 2019, 15:03
  2. delay in redundancy
    By hajjsaid99 in forum zenon Network
    Last Post: 29th June 2015, 15:08
  3. Has WebServer in Demo mode WebServer or WebServer Pro functionality?
    By stolyarov_as in forum Webserver/Webclient
    Last Post: 2nd April 2014, 13:54
  4. PLC redundancy
    By gyu in forum Drivers
    Last Post: 17th May 2011, 05:29
  5. Routing on WindowsCE
    By sebastiank in forum zenon Operator
    Last Post: 28th August 2007, 10:01
