Thread: String Value comparison to operate the Boolean value
    Beitrag String Value comparison to operate the Boolean value
    I am using Zenon 7.6
    Please help me to compare two string values for example 'current primary server & secondary server' based on this internal Boolean value has to be changed.
    @condition-1 String value1 = String value2 ==> Boolean Value =1
    @condition-2 String Value # String value2 ==> Boolean Value=0
    753
    Default Re: String Value comparison to operate the Boolean value
    if "string value2" are fix, then you can link variable with a string reaction matrix calling zenon functions 'write set value' to this BOOL variable.
    if "string value2" is a variable then you can configure both string variables to be 'externally visible' and evaluate their values in the zenon Logic.
    11.05.2019
    Thank you, Great information
  1. Comparison of two string variables to activate color
    By TMeck9 in forum zenon Supervisor
    Last Post: 23rd January 2019, 09:08
  2. Replies: 2
    Last Post: 22nd February 2016, 09:39
  3. Get the value of a boolean variable
    By cdaly2001 in forum VSTA
    Last Post: 3rd September 2014, 01:54
  4. String length field for STRING variables.
