Showing results 1 to 1 of 1
Thread: Cursor and timestamp in extended trend
    01.03.2018
    8
    Default Cursor and timestamp in extended trend
    Iím interested in how the timestamping on x-axis (abscissa) in an extended trend works. Does the timestamp of a following measured value change if there is no change of the measured value? I archive my data every 15 minutes. So when there is no change in value you see every 15 minutes a timestamp for the same value (Trend_no_change_1 and Trend_no_change_2).
    What happens in between those 15 minutes? In Trend_change_in_value_1 you can see a change of the measured power from 720 to 750. After that I didnít change the value, but the timestamp (two times after 11:30:00), but the cursor has still the timestamp 11:30:00 (Trend_change_in_value_2) until there is a change in value (happened in Trend_change_in_value_3) or 15 minutes are over.
    I would like to know if there is a possibility to set the cursor to the right timestamp, so if the cursor is on 11:32:11 that date is shown and not the date of the last change or last archiving (not 11:30:00).
    Attached Thumbnails Attached Thumbnails Trend_no_change_1.png   Trend_no_change_2.png   Trend_change_in_value_1.png   Trend_change_in_value_2.png   Trend_change_in_value_3.png
  1. [Extended Trend] Zoom in the trend with the mouse ?
    By eegabs in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 3rd April 2018, 09:47
  2. extended trend options
    By kasimosman in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 21st February 2014, 15:23
  3. Extended trend with opc-variable
    By robcha in forum Drivers
    Last Post: 17th October 2012, 09:17
  4. 6.22 -> 6.51 Trend Cursor not shown
    By brc in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 10th January 2012, 14:11
  5. Extended Trend HD Depth
    By shikra in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 10th May 2011, 23:36
