Thread: How can I display zenon Logic in zenon Runtime?
    16.05.2017
    2
    Frage How can I display zenon Logic in zenon Runtime?
    In zenon Logic editor, it is able to see how my logic runs with zenon Runtime in real time by activating the [On Line] button.
    I have seen it once at an exibition that zenon Runtime has a screen and it displays how logic runs as like I have mentioned above.
    I wonder how can I create the screen, for me to facilitate a troubleshooting in a special condition.
    Kindly advice.
    My zenon version is below.
    - Version 7.60 SP0 Build39532 64Bit
    - Integrated Workbench Version 9.1 Build 1
    Thanks.
    15.11.2016
    106
    Default Re: How can I display zenon Logic in zenon Runtime?
    This is done with an ActiveX element.
    See the help chapter:
    Manual > PLC Diagnosis > zenon Logic Monitoring Viewer
    Hope this helps.
    BR,
    Georg
    16.05.2017
    2
    It helped me a lot. Thank you.
  1. zenon logic to zenon supervisor
    By MJ in forum zenon Supervisor
    Last Post: 26th July 2019, 10:25
  2. Zenon Logic to check if a Zenon Variable is online
    By doublem in forum zenon Energy Edition
    Last Post: 28th March 2019, 13:06
  3. Zenon to Zenon Logic communication issue
    By joelprasad in forum zenon Supervisor
    Last Post: 23rd February 2019, 18:03
  4. zenon logic doesn't communicate with external variables in zenon
  5. Re: zenon logic doesn't communicate with external variables in zenon
