Thread: Zenon Operator freeze
    29.01.2019
    Default Zenon Operator freeze
    Hello
    after installation of windows OS updates the Zenon Operator start to freeze without any visible reason
    close the application and reopen again solve the problem for couple of hours but it's came back after some time
    please help to find windows KB update which stuck the program
    07.08.2018
    10
    Default Re: Zenon Operator freeze
    Which zenon version and build do you use? and also which windows (Build?) ...?
    Did you update your Zenon after crash?
    https://www.copadata.com/en/support-services/knowledge-base-faq/
    King regards,
    25.06.2012
    157
    Dear danyr,
    Welcome to COPA-DATA Forum.
    To better assist you it is required sensitive information about your local system so that a public forum is not the right place to continue with this topic.
    If the problem still persists, I would recommend you to contact your local COPA-DATA Support team.
    All the best,
    David Cerdeira
  1. Zenon operator station
    By sandeep2018 in forum zenon Operator
    Last Post: 26th July 2019, 10:02
  2. Webserver with Zenon Operator
    By joelprasad in forum Webserver / Webclient Setup
    Last Post: 5th September 2018, 09:21
  3. error when installing zenon 7.6 operator
    By eden212 in forum zenon Operator
    Last Post: 23rd January 2018, 07:51
  4. Use of Zénon Operator ?
    By florian in forum zenon Operator
    Last Post: 9th June 2015, 12:51
  5. VBA wizards freeze on some computers
    By markclemens in forum VBA
    Last Post: 30th November 2007, 10:31
