Thread: Internal Variable Calculation "Network"
    27.08.2008
    50
    Default Internal Variable Calculation "Network"
    Hello!
    Does someone wich phrase i would need to set the calculation of some internal variable sub items to "Netwok" with VBA in Zenon?
    Thank you!
    880
    Default Re: Internal Variable Calculation "Network"
    the property is called "Local"
    so .DynProperties("Local") = False sets the calculation property of the internal variable to "Network"
    To find such properties of zenon objects (Dynproperties) you can do this either via teh "DynPropertiesEnum" functionality or simply via exporting the variable in to xml file and look for the desired property.
    regards,
    880
    of course this information is also available in the VBA help documentation
    -> see node "Variable" -> DynProperties -> Internal Variable [ED] -> Local
  1. How to create a "Time Counter" variable?
    By lephis in forum zenon Supervisor
    Last Post: 24th August 2009, 11:17
  2. Replies: 2
  3. Replies: 5
  4. system variable "last open picture"
    Last Post: 7th April 2008, 13:50
  5. "variable image remanent" setting is not saved
