Thread: Boolean variable returning value as "inf" instead of 0 or 1
    15.02.2019
    5
    Default Boolean variable returning value as "inf" instead of 0 or 1
    Hi team,
    I have been checking some signals and one of the signal is returning a value "inf". The data type is BOOL and I checked the reaction matrix and it is configured correctly. Other signals with same RM is working fine. When I am simulating this 61850 signal in the device, the Zenon Alarm list is capturing it as "inf". I checked using IEC browser and I'm getting the right values. What must be the issue and when will "inf" come?
    753
    Default Re: Boolean variable returning value as "inf" instead of 0 or 1
    To be honest, I have no idea. I do not know any "inf" as value(!) in zenon AML. I was thinking that the AML column 'Value' displays only numbers...
    Is it really zenon or maybe some OEM system? What version are you using?
    If it is zenon, than I propose you to send the project backup to your local COPA-DATA Support.
    15.02.2019
    5
    I am using the Zenon 7.6 energy edition. I was also surprised by the value.
  1. Replies: 2
    Last Post: 22nd December 2017, 15:59
  2. Replies: 3
    Last Post: 28th July 2017, 01:08
  3. Replies: 1
    Last Post: 13th March 2017, 13:51
  4. Alarmmeldeliste Filter "nicht quittiert" ODER "anstehend"
    Last Post: 31st July 2012, 15:20
  5. Replies: 5
