Thread: file format supported in 3d configurator
    15.04.2019
    Frage file format supported in 3d configurator
    hi everyone, I want to know What 3D file formats does zenon support(can be inported into 3D configurator) and the maximum file size supported for each format?
    thanks for your time
    15.01.2016
    92
    Default Re: file format supported in 3d configurator
    Hello alfaexec,
    The 3D configuratior can support the following file formats up to a size of 50MB (due too performance reasons):
    • *.OBJ
    • *.3DS
    • *.STL
    • *.DWFX
    • *.STEP
    • *.STP
    • *.JT
    can also be found in our Help under Manual > Tools > 3D Integration > General
    Tobias Ritschel
    Default AW: file format supported in 3d configurator
    is there a file Format for 3D which is more performant than others? I had it tried with *.Step and *.stl. STL was a little bit better than STEP, but you have to wait a Minimum of 20 seconds till a screen is opened and can be used. Usability is different, or?
    Is there anyone who already use 3D-Objects in Zenon? What is your experience with it?
    Best regards
    JB
  1. Unexpected file format
    By eden212 in forum zenon Service Engine Operator
    Last Post: 13th March 2019, 13:57
  2. Supported OS
    By joelprasad in forum zenon Service Engine Supervisor
    Last Post: 27th July 2017, 12:30
  3. WebClient Screen Configurator
    By herberto in forum zenon Network
    Last Post: 23rd March 2016, 13:17
  4. WPFProperty not supported by the object
    By pwlodar in forum VBA
    Last Post: 23rd February 2015, 10:31
