Thread: object oriented programming abb Zenon
    09.04.2019
    7
    Default object oriented programming abb Zenon
    is there a way to work with objects in Zenon? i can make templates but when you make a change in the template the screens using that template dont change.
    Default Re: object oriented programming abb Zenon
    Hi Johnbar,
    Thanks for the post and welcome to the forum!
    Working with objects is possible in a number of ways.
    Templates can be applied to a screen (once). The template could contain linked symbols from the project symbol library, the symbol library in the global project or the global symbol library. When changing the symbol in the library, this change is taken over in all screens where this linked symbol is used.
    09.04.2019
    7
    Hi Mark,
    is that the only object oriented option in Zenon?
    Hi Johnbar,
    This was just one example, using screens and symbols, following your question.
    09.04.2019
    7
    Hi Mark,
    where can i find examples of these possibilities?
    John
    18.12.2017
    15
    Hi!
    Check the help-file, Manual > Project efficiently with the help of zenon > Object-orientation.
    /Fredrik
    09.04.2019
    7
    is there a tutorial video or explanation how to use objects/ data types? The help manual in Zenon only tells me it exists
  1. Object Model In VS2012
    By allmendinger in forum VSTA
    Last Post: 2nd August 2013, 00:00
  2. How to get Object in Screens
    By jorgedatcom in forum VBA
    Last Post: 9th January 2012, 00:32
  3. Object oriented engineering
    By lephis in forum zenon Supervisor
    Last Post: 14th January 2011, 08:56
  4. Replies: 0
    Last Post: 4th March 2009, 09:50
  5. VBA Object Overview
    By robertf in forum VBA
    Last Post: 16th August 2007, 10:18
