Thread: Graph display
    nblanquart Gast
    Default Graph display
    I would like to display two variables in the same graphic. The formula is:
    temperature = f(power)
    Both of the variables are floats. Is that possible to display them using this formula?
    Thanks for your answers
    Default Re: Graph display
    with the dynmaic element "Trend element" you are able to display up to 4 variables at a time.
    If you need more sophisticated possibilities you must use the Extended Trend Module ( ETM ).
    Take a look into the documentation of both capeabilities and find out more!
  1. Trend Graph
    Last Post: 12th August 2009, 04:21
  2. Display Help File in Runtime
    By ionvalesareanu in forum zenon Supervisor
    Last Post: 4th June 2009, 17:49
  3. trend graph
    Last Post: 26th September 2008, 12:00
  4. display last open picture
    By dak2483 in forum zenon Operator
    Last Post: 5th September 2008, 18:57
  5. Display Text Value
    By lengele in forum zenon Supervisor
    Last Post: 18th December 2007, 13:50
