Thread: Database cannot be opened
    11.02.2019
    22
    Default Database cannot be opened
    Does anyone know how to solve database cannot be opened in zenon version of 7.60 that installed in OS system of Windows 2012 Server R2?
    Is it database problem will influence restore backupfile function? As for my case, the backup file can be selected but there was no showing any information regarding the file such as editor version, name etc....and the most important is the 'OK' option grey out.
    There was no error during installation.
    Any solution for my situation?
    Thanks and regards.
    25.06.2012
    155
    Default Re: Database cannot be opened
    Dear shaun,
    this is most probably a misconfiguration or an issue related Editor access to the zenon SQL database instance where the Editor project files and data is saved.
    Therefore I strongly suggest you to go through this checklist.
    You can also find other identical threads in the forum. For example: Cannot open project
    Good luck.
    David Cerdeira
    Last edited by david.cerdeira : 26th July 2019 at 10:35 Reason: Other threads available.
  1. Database cannot be opened! Error
    By jhines in forum zenon Supervisor
    Last Post: 22nd February 2018, 01:14
  2. Re: Database cannot be opened! Error
    By jobertraj in forum zenon Supervisor
    Last Post: 27th October 2014, 08:16
  3. Database Capacity
    By nomi589 in forum zenon Supervisor
    Last Post: 19th December 2011, 00:10
  4. Backup database
    Last Post: 17th October 2008, 13:49
