Thread: Reporting and RCB Data Points on IEC 61850 Driver
    13.02.2019
    29
    Default Reporting and RCB Data Points on IEC 61850 Driver
    Hello everyone!
    I'm configuring an IEC 61850 driver on Zenon Energy.
    I configured Static Report Control Block on my driver 850 (Both Buffered and Unbuffered) by PLC Browsing.
    It's mandatory to import on my Zenon database the RCB data points (like xxxxxxLD0/LLN0/rcb_B01/RptEna[BR]) to make reporting works ?
    Because If I don't import all data under xxxxxx LD0/LLN0/rcb_B01/xxxxxxx   (RptEna[BR] … And all other) the reporting doesn't work.
    And so What are the data point related to my RCB that I necessary need on my database to start reporting?
    Thanks!
    805
    Default Re: Reporting and RCB Data Points on IEC 61850 Driver
    If the PDU size (frame size) used by the IED (PLC) is sufficient and RCB are placed in LLN0 - then the only demand is to have in the project at least one variable from this Logical Device. The best candidate is always the LogicalDevice/LLN0/Mod/stVal[ST], as according the Standard you are not allowed to use services (so e.g. those for Reporting) from logical devices you do not know the current mode.
    But if the IED is using the PDU size smaller as needed for responses during the association and the check of its data model (in Wireshark: mms.errorPDU; in LOG the errors) then you have to create in zenon project at least one variable in LLN0 with FC=BR and RP; else the driver has too less information (as not received from IED) to access the RCBs in affected LN.
    13.02.2019
    29
    Solved!
    Thank you
  1. Replies: 1
    Last Post: 28th August 2018, 08:45
  2. IEC61850 Driver - Data Type
    By andrea.ornago in forum zenon Operator
    Last Post: 11th October 2017, 08:48
  3. Driver Simulation Project - 61850 variables
    By steven.costantini in forum Drivers
    Last Post: 25th September 2017, 07:41
  4. SICAM 230 IEC-61850 Driver Crash
    By bhavin_bvm in forum zenon Energy Edition
    Last Post: 28th March 2017, 11:51
  5. Problem with 61850 driver
