Thread: Context List
    26.02.2014
    36
    Default Context List
    I have a system where there is a context list for alarm causes.
    There are four PCs running Zenon, two line PCs (PC1 and PC2) and two servers (primary and standby).
    If I enter some alarm causes on PC1, they appear also on the list on PC2 as they should.
    However if I re-start server1 and it switches to server2 as the primary all alarm causes are lost. Switching back to server2 as the primary does not recover them.
    It would appear that re-starting the server deletes the data.
    Is there a way to stop this happening?
    15.11.2016
    106
    Default Re: Context List
    There was an issue with Context Lists and redundancy, which has been fixed.
    See this Knowledge Base entry:
    https://www.copadata.com/de/support-services/knowledge-base-faq/palarm-causes-do-not-work-with-redundancyp-2560/
    BR,
    Georg
    26.02.2014
    36
    Thank you.
  1. context menu
    By Shubham Ghatwal in forum zenon Supervisor
    Last Post: 3rd April 2018, 16:23
  2. multiple Commands in one context menu
    By marchelo in forum zenon Energy Edition
    Last Post: 24th October 2013, 09:03
  3. Replies: 10
    Last Post: 20th October 2013, 23:53
  4. Context menu Command in touch panels
    By kiltrox in forum zenon Energy Edition
    Last Post: 18th April 2013, 08:52
  5. Context menu with authorization level
    By fabio79 in forum zenon Supervisor
    Last Post: 18th October 2012, 09:21
