Thread: Zenon logic watchdog variable
    13.02.2019
    30
    Default Zenon logic watchdog variable
    Hi Guys,
    I'm using Zenon Energy 8.00.
    Is there any function block or method to check on HMI Zenon if the associate Zenon Logic project is running ?
    I would like to rappresent on HMI a light that is Green if Zenon Logic is running and a Red light if Zenon Logic is stopped, but I don't know how to realise this!
    Thanks to everyone!
    Marco
    891
    Default Re: Zenon logic watchdog variable
    My favorite solution bases on shared memory area (and internal drivers) between zenon and zenon Logic, steps:
    In zenon Editor:
    1. create an internal BOOL variable with name e.g. Logic_is_running. The variable properties:
    • 'Internal variable': Remanence = "Initial value";  'Initial value' = 0.
    • 'External settings': 'Externally visible' = yes
    2. create function of type 'Write set value' with name e.g. Logic_failure_indication; function properties:
    • linked with variable Logic_is_running,
    • 'Set value' = Off (0)
    • Options: 'Direct to the hardware' = yes
    3. in node 'zenon Logic (IEC 61131-3)' in properties of the project, in group 'Runtime':
    • ‘Function for failure recognition’ link with function Logic_failure_indication
    • ‘Failure recognition after [s]’ = 10s
    In zenon Logic Workbench:
    4. in ‘Fieldbus configuration’ add driver ‘Logic to SCADA connection’
    5. add in program the following code (here in ST-language):
    if not Logic_is_running then
        Logic_is_running := true;
    end_if;
    As result when Logic starts then zenon variable gets value TRUE (from Logic code), and when Logic stops then the function changes variable value to FALSE (after the time ‘Failure recognition after [s]’).
    Do not configure this time too short, as when zenon Runtime is busy (e.g. huge load of process data causing alarms or scrolling of big lists etc.), then it may happen that there will be temporary slow of access to the shared memory.
    13.02.2019
    30
    Daumen hoch Re: Zenon logic watchdog variable
    All right!
    Thank you
  1. Watchdog variable
    By eden212 in forum zenon Supervisor
    Last Post: 29th November 2017, 14:44
  2. Changing Variable Name in Zenon Logic
    By hamiiiz in forum straton / zenon Logic
    Last Post: 23rd June 2015, 13:50
  3. zenon logic doesn't communicate with external variables in zenon
  4. Re: zenon logic doesn't communicate with external variables in zenon
  5. Zenon logic
    By sidramsatyal in forum straton / zenon Logic
    Last Post: 1st July 2014, 09:45
