Thread: johnson ncm350‬‏
    17.09.2017
    18
    Default johnson ncm350‬‏
    hii is there a driver for johnson ncm350‬‏?
    23.11.2016
    4
    Default Re: johnson ncm350‬‏
    Hello eden212,
    in the datasheet of the the network control module you can see that this controller can communicate with an ALLEN-BRADLEY(r) PLC-5.
    Therefore you can use our driver:
    Using ethernet connection should work well with our driver.
    BR,
    MichaelL
    Attached Thumbnails Attached Thumbnails johnson_drv_allen.png   data_sheet.png
    17.09.2017
    18
    Thank you for your help but i get the following error
