Thread: Modbus and IEC-101 Protocols with Process Gateway
    07.03.2019
    Default Modbus and IEC-101 Protocols with Process Gateway
    I use 7.60 version of Zenon Energy. I would like to configure IEC-101 and Modbus protocols as slave in Process Gateway. Is it possible and how i can achive this?
    I will looking forward your answers.
    986
    Default Re: Modbus and IEC-101 Protocols with Process Gateway
    Make sure that you have the zenon Help - it can help
    from zenon Help: Manual > Process Gateway > General
    Several Process Gateways can be started on one computer.
    You can find further information on this in the Start chapter.
    my personally favorite method is to start via zenon function executed in AUTOSTART script; in Help: Manual > Process Gateway > Start > Start via zenon function
    The Process Gateway can - like any other Windows application - be started with the Start program function.
    a.Click on the button ...
    The file selection dialog is opened.
    b.Go to the zenon Installation directory:
    Program Files (x86) - 64-bit operating system
    Program Files - 32-bit operating system
    c.Select the file zenProcGateway.exe
    Configure the parameters that are transferred when the function is executed.
    example for Parameter: /ini:zenPG_IEC870_BUFFER.INI
    example from my file system:
  1. Modbus Process Gateway
    By avinash.malli in forum Gateways
    Last Post: 16th February 2016, 11:14
  2. Modbus Process Gateway
    By hussaini in forum Gateways
    Last Post: 12th November 2015, 14:08
  3. Process gateway Modbus
    By archie in forum Gateways
    Last Post: 13th November 2014, 07:21
  4. Process gateway(Modbus)
    By ansab.tp in forum Gateways
    Last Post: 12th February 2013, 12:33
