Thread: Zenon Hanging
    Unglücklich Zenon Hanging
    Hi Guys
    I am facing a difficulty, help me if you could give any solution.
    I am having a Virtual Machine with 200GB of RAM, 3.5TB of Hard disk and 4 Xeon Processors.
    Now telling about my project, I have the following
    1. 22 Sub-Projects
    2. Nearly 3 Lakh Variables
    3. Over 50 Drivers (IEC-61850)
    4. Total 65 Historians (Almost all variables in Historian)
    5. 22 Zenon Logics
    6. 3 Process Gateways
    The Application was fast initially, but after adding projects it started hanging terribly. When I see the Task Manager the CPU Usage never Exceeds 30% and Memory usage never exceeds 25%.
    Is this a limitation of Zenon ? If not what to be done to make the application utilise the Hardware entirely.
    The Reload Function is not working, and the SQL Export function for few projects are also not working.(This function is working if I run the Project seperately).
    Many times the Runtime never starts even after 4-5 hours.
    Any solution to handle these many projects??
    921
    Default Re: Zenon Hanging
    What zenon version are you using?
    Have you looked in Task Manager not only on summary CPU load, but on usage of each procesor separately? If the use of 1 of those 4 processors is > 80% then this is the "bottleneck".
    Hmm, "Lakh" - is it the Indian numbering system equal to one hundred thousand? so you have 300 000 variables?
    Zenon 7.60 Build 54483.
    I will check the the Processors individually and revert back.
    921
    and compare with zenon 8.00, between 7.60 and 8.00 we sped up the Runtime and drivers registration. If it will be still not enough - check with (Beta) 8.10.
  1. Importing variables for the IEC870 driver is hanging
    Last Post: 10th December 2007, 13:51
  2. Replies: 0
