Thread: XML utf-8
    12.10.2016
    7
    Default XML utf-8
    In a project i read some information from a xml file with zenon logic.
    I haven't got problem.
    I need to translate my project in chiness, and i have some problem with convertion.
    this my xml file
    <?xml version="1.0" encoding="utf-8"?>
    <DESCRIPTION><TITLE>0-与PLC连接不工作</TITLE><MODULE>@GENERAL</MODULE><DIAGNOSIS>Qiyun : PLC不工作\n网络故障\nJie : 检查PCL供电\n检查网络布线\n检查HMI网络配置</DIAGNOSIS><TIMELEFT></TIMELEFT><DOC>C:\GCX\ROBOACCESS\RT\FILES\zenon\cus tom\additional\GCX\DOC\ALARMS\ZH\0.html</DOC><MEDIA></MEDIA><OCCURENCE></OCCURENCE><MODULE>1</MODULE></DESCRIPTION>
    when i read the TITLE i have in return in a string:
    0-与PLC连接不工作
    this is my zenon code
            XMLS := _APP_FOLDER + 'RT\FILES\zenon\custom\additional\GCX\DOC\ALARMS\' + sys_lang_initial + '\ALARM_ID_' + RIGHT(_SelectedObjectId, len(_SelectedObjectId) -1 ) + '.xml';
            hTag2 := XmlParseDocFile(XMLS);
            //(hTag2);
            xmllasterrord := XmlLastError();
            xml_tag_parent := XmlGetParent( hTag2 );
            xml_hchild_tag := XmlFirstChild(hTag2,'');
            tt := XmlGetTagName(xml_hchild_tag);
            //title
            XmlGetTagCont(xml_hchild_tag,TTT);
            ALARM_DESC_TITLES := TTT;
            //MODULE
            xml_hchild_tag := XmlNextChild(hTag2,xml_hchild_tag,'');
            ALARM_DESC_SUBTITLES := TTT;
            //DIAGNOSIS
            ALARM_DESC_DIAGNOSIS := TTT;
            //TIMELEFT
            ALARM_DESC_TIMELEFT := TTT;
            //DOC
            ALARM_OPL_PATH := TTT;
            //MEDIA
            ALARM_MEDIA_PATH := TTT;
            //OCCURENCE
    //        ALARM_DESC_TITLES := TTT;
            //MODULE
            ALARM_DESC_MODULE_NUM := any_to_int(TTT);
            XmlFreeDoc( hTag2 );
    They have a solution?
    23.10.2018
    14
    Default Re: XML utf-8
    Hi Johann,
    The problem comes from the fact straton/zenon-Logic is not coded in Unicode.
    Then, using special characters, few things may not work, like what you observe here.
    The solution is often to really use a specific OS (Korean or Chinese OS for example).
    Anyway, if this can solve most of this kind of errors, it does not work 100% of the time.
    Re-encoding all of the straton/zenon-Logic product in Unicode is on our tasklist, but
    Unfortunately it cannot be done quickly as it means re-doing almost everything from the beginning!
    I hope with a Chinese OS you will manage to reach your goal.
    (Otherwise, we could try to find another solution, but for the moment nothing comes to my mind, sorry)
    Anthony
