Thread: Configuration of meter variables
    04.03.2019
    4
    Default Configuration of meter variables
    I Need Support for configuring of PQM NEXUS 1500 METER BELOW VARIBALES.
    MAXIMUM/MAX & MEAN VALUES OF VOLTAGE (PH & LINE)
    MEANV/MAX & MIN VALUE OF PER-PHASE ACTIVE POWER (MW)/REACTIVE POWER/APPARENT POWER.
    MINIMUM/MAX &MEAN VALUES OF LINE CURRENT PER-PHASE.
    I DONT HAVE DIRECT LOGICAL NODES.
    SO PLEASE SUPPORT ME HOW TO CONFIGURE CAN U GUIDE I DO ONLY THROUGH HISTORIAN OR ANY OTHER WAY IS POSSIBLE.
    Default Re: Configuration of meter variables
    Hi jameerbashaias,
    I'm not sure if I understand correctly. Do you mean that the IEC 61850 MMS server of this meter, does not provide logical nodes in its address space that provide the data that you need?
    The points database for the DNP3 Outstation implementation for this meter seems quite comprehensive and provides all kinds of data including minimum and maximum values, as well as a mechanism to reset minimum and maximum values. Perhaps getting the data through DNP3 is an alternative?
  1. DNP Configuration
    By philipe0136 in forum zenon Supervisor
    Last Post: 7th March 2019, 23:57
  2. Iec 870-103 driver and variables configuration
    By dahmane in forum zenon Energy Edition
    Last Post: 12th February 2019, 13:02
  3. OPC UA configuration
    By mehrdad66 in forum Drivers
    Last Post: 5th November 2014, 08:13
  4. OPC Client configuration
    By luca.bardon in forum Drivers
    Last Post: 17th October 2012, 10:08
  5. facePlate configuration
    Last Post: 25th January 2012, 00:47
