Thread: Elements Invisible Sometimes
    14.09.2017
    6
    Default Elements Invisible Sometimes
    In Zenon7.20 elements are getting invisible sometimes please refer screenshot. It is properly running from last 4 months suddenly issue occurs and now it seems that it is solved but we are not able to found the root cause for the same.
    Operating system windows 8.1. Windows updates are stopped.
    Can you please suggest causes behind this issue.
    Rahul.
    741
    Default Re: Elements Invisible Sometimes
    Possible explanation could be that zenon Runtime is not displaying screen elements linked with not existing functions, variables or symbols; or variables never received from a driver.
    On your screenshot: what kind of screen elements are you using? what is linked with?
    14.09.2017
    6
    It is working properly now with same RT so how can we say that variables never receive from driver or not existence of variable?
    In above screenshot I have used "Combined Element" as element and attached variables with Boolean datatype.
    also for Numeric elements we have faced same issue as attached.
    PLC: Siemens 1200 and driver used is "S7 TCP-IP driver".
    Rahul.
    741
    If variable has no value at all (as never received from PLC) then depending on screen element type the element will be not displayed or will be empty. With a right-click on element you can see (per default, context info can be deactivated) the name of variable, and - if it has a value - the status "spontaneous" and maybe some more status bit descriptions. So no status text - no value.
    Alternatively, you can check the variable values and status bits in screen type "variable diagnosis".
    Have you checked in LOG (Diagnosis Viewer) if the S7 TCP-IP driver logs some errors?
    14.09.2017
    6
    Hello Ursula,
    Sorry for the late reply.
    The issue occurring to customer on random basis, so it is difficult to run diagnosis viewer and wait for issue to come to get the log files.
    I have observed one thing, while this error mention above occurred at same time driver executable file (i.e. s7TCP32.exe) is not running.
    I had take trials also by manually exiting s7TCP32.exe and found same error.
    Is there is chances that particular executable file gets stopped by SCADA itself? or any other way other than human intervention?
    Or does we get any windows log when driver stop?
    Rahul Indore.
  1. Elements.Type immer 0 ??
    By drosewick@hofmann-global.com in forum VSTA
    Last Post: 5th August 2011, 22:14
  2. how to remove windows elements during run time
    By tanveerali in forum zenon Supervisor
    Last Post: 25th May 2011, 23:28
  3. Resettting Flashing of Elements
    By shikra in forum zenon Energy Edition
    Last Post: 22nd April 2011, 00:09
  4. how to change text and color of invisible button
    Last Post: 14th February 2011, 00:09
  5. Restore deleted links in elements
    By sebastiank in forum VBA
    Last Post: 28th August 2007, 09:58
