Thread: Can zenon read data from a *.csv file
    27.08.2015
    8
    Default Can zenon read data from a *.csv file
    I have a *.csv file with variable.value and variable.timestamp. How can I use zenon to read data from *.csv file to adapt with internal-variable.value and internal-variable.timestamp. Type of variable is real.
    Thanks & Best regards,
    Minh
    891
    Default Re: Can zenon read data from a *.csv file
    Must it be an internal variable? Would be easier with a stratonNG variable…
    To set the timestamps of an internal variables you have to configure in project.ini (v. 7.50) the INTERNALDRIVERWITHSTATUS=1 or, in 8.00: project - 'Runtime settings' - 'State/Timestamp for Intern Driver variables'. Else internal variables have the local timestamp - the moment of value change, and you cannot manipulate it. But with activated option all internal variables are the licensed tags, thus to take a process variable could be a better choice.
    In zenon Logic you can pro 1 cycle read a line of CSV file and update the value and timestamp of the stratonNG variable accordingly. Then each cycle will transfer one variable value and time to zenon.
    zenon Logic supports file operations and has also FBs to set the timestamp of the variable (while changing its value), e.g. SymbVsiSetDate(), *Time() and VsiSetDate(), *Time().
    I'm moving this thread as it is nothing specific for Energy.
    27.08.2015
    8
    Thank you very much for your reply.
    We can use stratonNG variable. Could you please give me more detail to do this - I'm not an expert on program
    27.08.2015
    8
    I tried to write variable to a *.csv file but how can I defined the LIST:
    891
    I'm totally confused: in the first post you want to read values and timestamps from a CSV file you already have, but in your example you are trying to create and write to a new file.
    The CSV files are string files. Thus, to read and use the content, you have first open the file (F_ROPEN) then read the content of the file line by line (FM_READ) and split the line (a string variable) to 3 (?) strings - with a value and with date and time components of the timestamp (all as text). As I do not know the format of your file lines I can only generally propose to then encode these 3 texts to numerical value and timestamp components, using e.g. any_to_DINT, any_to_time, etc. Then, you can assign the encoded value and timestamp components to a stratonNG variable (*VSISet*).
    In this Forum there is section for zenon Logic related question. If you need more detailed guidelines then post an example of the file line there, or contact officially your local COPA-DATA Support.
  1. Replies: 1
    Last Post: 14th November 2018, 10:48
  2. Read data from backup folder
    By slaff in forum VSTA
    Last Post: 4th April 2011, 23:12
  3. read-back user administration data by Transport
    By marchelo in forum zenon Supervisor
    Last Post: 20th June 2010, 23:49
  4. How can I read this two type of Data register?
    By michael_k in forum Drivers
    Last Post: 24th November 2009, 16:23
  5. Replies: 2
    Last Post: 9th June 2009, 12:53
